1 - 4 of 4 Posts
hello all i have embarked on a daunting task to put a JDM EJ20 motor with turbocharger in my non turbocharged 2006 subaru impreza wagon i got the new motor and am looking into what i need to do this swap i already figured id need to replace the ECU but i was wondering if i could pull a dashboard cluster out of an existing WRX and put it in my impreza, will this work? if so how much of the harness do i need, or where can i find one? if someone could help me with this it would be great i am just trying to figure out if this is oossible and i havent gotten a straight answer.
thank you for your time, Chris
+1 here
Pulled the EJ25 out of my 08 Impreza wagon and planning the same swap. Have the EJ20 with wrx hood coming in. Any advice is appreciated
Super Moderator
2000 RSTi
They made ej20 engines from 1989 to the mid 2010s. I assure you the wiring is not compatible between any of those variants and your car.
What you need to do is contact
And see what they can do for you, as far as making a compatible harness.
You will need the harness and Ecu to go with that motor, also you will need to notch your crossmember or change it over to the turbo crossmember
1 - 4 of 4 Posts
