1 - 2 of 2 Posts
06 obp wrx, 87 bmw 325
Hey!
I'm in the process of gathering the remaining components for my suspension Swap but I have a question regarding WHICH bushings to use.
Vehicle: 98 or 01 impreza outback sport
(I have both)
Parts for swap (based off of 02-07 wrx; reference: nasioc suspension pinned post) :
1. STI Group N Strut Mounts (Front & rear)
#: b0310fe000
2. KYB AGX Struts
#'s: 734007 / 734006 / 733011 / 733010
3. H&R Sport Springs (1.8" Fr / 1.5" Rear drop) #: 29472-1
4. Whiteline Fr/R Sway Bar Kit with fr/r end links (Kit #: BSK004)
Front Sway Bar #: BSF20Z
Rear Sway Bar #: BSR20XZ
Front & Rear Sway Bar End Links #: KLC31
5. 4/2 pot conversion (backing plates, calipers, etc)
6. SS brake lines
Simply put... Which bushings would I actually need?
Based off 02-07 OR 98-01?
Administrator
2000 RSTi
I'm not sure about your part numbers, for example, the KYB AGX's come up as 93-01 Impreza, but the Group N Strut mount p/n comes up as 02-07 Impreza, and only for the fronts.
I would buy bushings to match the strut application, and if possible, get everything designed for 1st gen Impreza.
1 - 2 of 2 Posts
