I've been dealing with a stability issue at high speeds for about a year now. My 2000 RS rocks side to side on the highway, mostly when I turn slightly to the left (interstate turns or on/off ramps). It seems to be in the rear end, kind of a fish-tailing feeling.
I've combed through other forums and a lot say its tire pressure, alignment or struts while a few mention random loose suspension parts or bolts.
Keeping an even tire pressure all around helps, but doesn't solve the problem completely. I've jacked up my car to shake and rattle every rear end part I can, but nothing seems loose or amiss.
I'm thinking about getting new struts, partly to see if they solve this problem, but also because I tow a small fishing boat with my Subie and I'm looking to get some beefier support back there.
Does anyone have any suggestions on struts that will hold up to the added stress of a trailer or the weight that comes with lots of fully loaded (bike racks and heavy vacation gear) traveling? Now, any suggestions that won't break a young married man's bank?
Can struts that are on their way out cause this? I feel like my back end sags a significant amount when I'm packing the car up for vacations and whatnot.
On a side note: I noticed a high-pitched, ear-ringing-like noise coming from the front at high speed, about 70 mph and at 60 mph, but not at all in between. At idle my ac compressor pulley is pretty loud when it's not engaged, so I think that could be it. Can I grease this or will that ruin it? I'm just hoping its not a front bearing or anything like that.
Thanks
Thanks
