1 - 4 of 4 Posts
All of these are used parts. FXT parts have 125K, GC parts have zero miles on them unless noted otherwise(body parts etc etc), GD WRX/STI parts have about 79k
2006 FXT (all stock unless noted otherwise)
Springs and struts(will seperate) 2 struts are leaking. $50
Intercooler $50
Trans mount $5
Driveshaft $35
Subframe $40
Power steering rack(needs rebuild) $10
Lateral Links(needs 2 bushings) $10
Trailing Arms $10
Front sway bar $10
Rear sway bar $10
Motor Mounts $10
Secondary air pump(has 50 miles on it new from subaru) $200
Control Arms $10
Air Box $10
Subframe spacers $5
Headlights(1 leaks) but lenses are in great shape $75
Steering Wheel $35
GC/RS
Ej251 - has STI nitraded crank, pistons and rods(all new), delta 1500 cams, grimmspeed crank pulley, 99 intake manifold(you can use any top feed injectors), Phenolic spacers, All new Gates timing kit and water pump, All new oem gaskets. WILL NOT COME WITH MOROSO PAN UNLESS YOU WANT TO PAY FOR IT $1650.00
Custom supercharger kit(only thing you need to finish is get a AWIC and weld on your own throttle cable bracket. Has a jaguar m90 blower with teflon coated rotors. Comes with pipes, throttle body adapter, blower, idler bracket, belt, intake, blower mount. Blower alone is rare one and cost me 475 $600
Mega squirt PNP ECU $250
RS 5 speed $300.00
RS differential with 25k miles $100
RS Driveshaft $35.00
ACT HD Clutch Brand new $300
ACT Flywheel Brand new $175
NEW OEM Clutch fork $20
RS Sedan Spoiler(prepped for paint) $40
RS Side skirts(missing passenger rear) $40
Sunroof track and motor $25
Hood Scoop $25
Mirrors $25
Hood vents $25
Radiator $20
wind visor $10
P1 replica Lip $50
Tank straps $10
Powdercoated 01 manifokd $50
near complete ej251 manifold $25
gauge cluster $20
ISIS Pitch Stop $35
USDM grill $20
steel gas door $10
RS Front crossmember $25
GD WRX and STI
07 STI rear subframe$50
07 STI rear Sway Bar $25
07 STI Fuel pump 25k miles $20
07 STI lateral Links $200
04 STI Struts(1 bent perch on the front but has perfect inserts) 45k miles $150.00
04 STI Rear top hats $20
05 WRX front and rear calipers(painted and fresh seals) $100
05 WRX Rear axles $40
05 WRX Front Sway Bar fresh powdercoat $20
05 WRX Rear sway bar fresh powdercoat $20
06 WRX AC Compressor $50
06 WRX Powersteering Pump Brand new(cardone brand) $50
EJ206 Long runner intake manifold $50
Prosport Oil sender adapter $10
I will add more as i keep going through stuff. all prices are OBO. I will ship at YOUR expense Less Pm me for pictures the facebook link is included below. Message me through messenger or 6309473666
Log in to Facebook | Facebook
2000 RS Coupe
Interested in the EJ251 engine:
Where are you located? What is the additional cost of the Moroso pan? I'm assuming that this is assembled. Were the bearings upgraded or replaced with OEM parts. Has it been run since assembly if that is the case? Do you have pics? Thanks.
1 - 4 of 4 Posts
