Transmission drain plug (21mm by the exhaust merge) on my ’00 OBS (manual) is extremely tight. Even the shop I took it for another service said they were scared of causing damage. The rear was similar and I used my jack to put upward pressure on the plug, but the front plug is at an odd angle for this trick.
Does anyone have tips for safely removing the plug? I have no idea if or when it was loosened.
Alternatively, can we siphon the gear oil from the diff dipstick? Would I be able to extract enough considering the internal structure and oil thickness?
