2005 Impreza 2.5RS
Hi guys,
I have strange noise when revving/accelerating at around 3-5K RPM. The sound is like turbo spooling/gas under pressure escaping with huge pressure. Noise is coming from somewhere under, and it is very hard to say from where exactly. My car is 2.5RS stock (N/A). Please help.
2000 2.5RS
Well, just for a little more background, is this a high pitched sound, like a whining? also, if you could have a friend rev it for you while you're near where you think it's coming from, it can help you identify the problem a little more easily. Don't try to figure it out while you're driving or you just won't get it.
99 RBP RS Coupe
My car does a whistling noise when I'm accelerating from 3rd-5th gear. It does kind of sound like spooling too. Only happens when I drive though not when I rev, and it does seem to come from under my car. I was told from people and researching that it was probably my aftermarket exhaust.
1998 Impreza 2.5RS
Aftermarket exhaust? check and see if there are any extra spots for O2 sensors.
When I did my exhaust there was an extra spot on my midpipe that I had to put a plug in.
2005 Impreza 2.5RS
Discussion Starter #5
It does feel like gases exit with high pressure from under the car. So exhaust might be a reason. It only happens when I rev hard, otherwise no sound. I am thinking there might be a hole like you said that might need patching. I'll wait for spring to check on exhaust. Thanks!
