1 - 3 of 3 Posts
http://www.fastwrx.com/rebradkit.html
Rear Brembo Adapter Kit (02-05 WRX)
This kit allows you to bolt STi Brembo rear calipers to your WRX. You get two custom-made caliper brackets, hardware, and special DBA rear rotors that have the OUTSIDE diameter (316mm) of the STi Brembo rotors, but the INSIDE diameter of the WRX parking brake. (Note that you CANNOT use the original WRX STi rotor, because then your smaller-diameter WRX parking brake will not reach the rotor.)
You supply the STi rear calipers and brake pads (or buy the pads from us). You'll have to bend or remove the rear dust shield to clear the new rotor.
06-07 WRX models have a different rear backing plate, so they don't need the caliper mounting brackets to bolt the STi calipers on; they just need the rotors, available separately HERE.
Kit includes two rear brake rotors, two caliper mounting brackets, and hardware. Fits all 2002-05 WRX, and 2005+ Legacy GT, 2002+ Forester XT.
K05745
$640.00
1 - 3 of 3 Posts
