Well, I've got a two day event at Gingerman Raceway this coming weekend. Two of the last things on my list to do were to weigh/corner balance the car and to install an oil cooler.
To the second point...I wasn't wild about any of the oil cooler kits out there, so I decided to piece one together myself.
I went with a CSF heat exchanger because I liked the in/out position of the lines and thought I could tuck it nicely between the radiator and support. Which proved to be correct...roughly like so (mocked up)
I also went with an RCM oil sandwich plate because it puts the in/out lines right in front under the timing cover. This allowed me to get the lines to be very short with very clean routing. Although...I'm a little mad that the kit didn't come with all the hardware necessary to mount the plate to the block. Luckily I had an oil filter stud thing (black threaded bit) on an old block in the garage.
Everything assembled and routed a coolant line bypass since the factory cooler is removed.
And here it is mounted and all buttoned up with the radiator re-installed. Super happy with the packaging here...
Finally, I filled it all up with new Motul oil. Went with 15w50 this time based on some reading and feedback from another one of my engineer friends who does a lot of track driving. That and reading a lot on the facebook groups about what people are using in 207's on the track. this 300V has the nicest packaging I've ever seen for oil.
Also, I started to make an intercooler shroud. Not too stoked on this, and I need to figure out how to do the rear edge...but it's better than nothing for now.
Okay...On to weight and corner balancing. Before I tore the car down and when it had a full interior, EJ20G swap and about 1/4 tank of fuel, the car weighed about 2750lbs. I took a lot of weight out during the build, but I also put a significant amount back in with the cage. So, I was hoping that I broke even and would be roughly around 2800lbs. With about 3/4 tank of fuel the car weighs 2750...So basically achieved the goal and broke even on weight.
As for corner balancing...I suspected I would have some trouble here. When I set the ride height on my coilovers, the left rear needed to be about 1/2" to 3/4" longer than the right rear to achieve the same ride height. This car was wrecked before, so the chassis could have some tweak or other demons hiding in it...however the car also has been on a frame machine and corrected to factory specs ( a long time ago). And, based on measurements when I was building the cage and replacing the quarter panels...I don't think there's that big of a difference side to side in the chassis.
I decided to play with the pre-load a bit. I took some pre-load out of the right rear which allowed me to lengthen the shock over-all to match the left side. This also corrected some difference in droop side to side. We were able to get the cross down from 60% to about 55%. Not great, but its an improvement. At some point, I need to go through and set droop / pre-load from scratch on all 4 corners. Anyways...here's the weight of just the car before adjustment, and the weight with me in it after adjustment.
So, overall the car is in good shape and I'm super looking forward to this weekend.
