You will need to remove the pistons and/or wrist pins first otherwise you'll only get it a few inches apart before the pistons bottom out in their cylinders. There are 4 access holes (2 on the front, 2 on the rear) of the block that are 14mm allen bolts (set screws?). Then you'll need the wrist pin removal tool from Subaru to get them out.
I believe there are bolts along the top and bottom seams of the block, those are apparent, then there ae bolts in the coolant channels around the cylinders, I think 6, but it might be 8.
Actually splitting it after all that is done... I'm not sure. I've never actually done it myself. I think you'll need to rap on it a bit with a mallet and pry it a bit, but I think overall it'll take a lot of effort. I've got a buddy with w VW block that just won't split... I can only predict how a decently-worn scooby block does.
Good luck, though.
