I'm thinking about doing some various upgrades to get more light in front of me, because I live in a pretty rural area and worry about deer and things all the time. I have a decent idea of what I want to to, but I wanted to get other people's advice and experiences. I should also probably note that this is all with a pretty tight budget, so cheaper=better!
First of is the headlights. I don't want to do anything crazy here because I don't want to blind other drivers or anything. I was considering just upgrading the bulbs to something +30. Any experiences? And since I'm making a thread anyway and I'm not going to search, anyone want to tell me what the headlight bulbs are?
Next I would make new harnesses for both the headlights and the fogs. I've heard that this alone helps output a little bit because it avoids the voltage drop you get across the switch. Not sure I believe it fully, but I figure might as well. Has anyone made their own harness/relay setup? I'd be interested in knowing what gauge wire you used and how you routed things. It would even make a nice DIY for someone that's done it...
Onto the fogs. This is the main part I'd like opinions on. The cheapest upgrade I was looking at was a set of +90 bulbs in the stock housing. What I'd like to know is how that compares to normal Hella 500s or 500s with the same +90 bulbs. Also, what are the 500s made out of? I'd run a 110watt bulb in the factory housing, but I'm too afraid of melting it, so will the 500s take it? I know this isn't exactly legal, but I'm not that worried as long as I treat it like high beams. Are there any other good budget options?
Finally, auxiliaries. I really don't want another set of full size lights, just because I don't like the way they look, but I'd consider throwing on a set of small ones. PIAA makes some nice ones, but they are very expensive. I've seen cheap ones, but I don't know if they could throw light any better than my high beams even with better bulbs. The second part of this is where should I mount them. I don't want them to be obtrusive at all, so I was thinking about in the main bumper opening, but that's a little low. The only other clean looking thing, IMO, is to mount them in the grill, but I'm not sure how to do that nicely. I've seen night shots with someone who had done this, but I couldn't tell ow the grill was modified.
Sorry for the long post. Basically, I want more light, I don't care about the look of the light, but I do care about other drivers and cost.
Thanks!
Thanks!
