Alright guys well im deep in the process of of build my rs. Before i ask my questions ill list my set up and condensed parts list.
2001 2.5rs
ej257 block
-cp 8:1 compression
-Manley h beam rods
-sti crank
-all balanced
-td02 turbo
-wrx manifold
-wrx up pipe
-ebay down pipe
-HKS carbon cat back
-9x6 aem dry flow filter
-cx racing y-pipe kit
-wrx intercooler
-ebay fpr w/jegs gauge
-Greddy e-manage ultimate
obviously there is a lot more to my build but this is all that pertains to my questions
1) The big question i have is how much boost can i run on stock 280cc injectors with the fuel pressure turned up.
-I know the max ill want to run is about 90psi and i plan to upgrade the injectors when i have the money for them, but can i run stock internal wastegate pressure with the 280cc injectors(which ive heard mixed answers some say its 7psi and other swear its 10psi? if you could help there to that would be great)
2) I know i need the wrx water pump but what exactly do i need to make it all work. For example, will the rs thermostat, plastic 90, and the hose work or do i need the wrx parts, and if so what parts would they be?
THANKS IN ADVANCE FOR THE HELP, charley
FYI: I have search for hours and cant find a clear answer so i will be grateful for links or answers
2001 2.5rs
ej257 block
-cp 8:1 compression
-Manley h beam rods
-sti crank
-all balanced
-td02 turbo
-wrx manifold
-wrx up pipe
-ebay down pipe
-wrx intercooler
