1 - 10 of 10 Posts
hey just installed a twm sts and a new twm shift knob, took me about 30 min
anyways now when i'm driving it is much harder to up and downshift, like i'm forcing the shifter into gear
do i need to break it in or something? (like new brakes or tires) or what do you think is the problem
my throws are shorter but when i had a stock shifter i could just lightly nudge the shifts into place but now i have to pull and push
Low&Slow
1965 VW Bug,2001 drz400 sumo
over-tighten the the nut and bolt that holds the shifter to the linkage?
Discussion Starter · #4 ·
i haven't yet installed the hard bushings, right now ive got the stock in
and no i didn't over tighten the bolts, their actually pretty loose, but not like wobble loose or anything, snugly loose
maybe if i just work the shifter for a while in park with the car off it'll loosen up
13 Years of RS
2005 Toyota Corolla :(
A short throw shifter makes the throw shorter, but they also decrease the leverage at the same time, making for a little harder force needed. But it sounds like you are really pushing hard, so I'm going to go with the over-tightened nut possibility, too. But keep in mind that it's going to take a higher effort regardless.
Did you grease it up? Make sure you put a good amount in there and on the bottom of the shifter itself. Rub it all around, and give it some time after you install to "break in" of sorts.
2015 WRX+TE37ta
Poo, I was hoping that maybe the bushings just needed to be worn in. It wouldn't hurt to just put the bushings in and see what happens. Maybe somewhere along the way you'll solve the problem without knowing it :)
Discussion Starter · #9 ·
yeah, on the twm site it said that it might be hard to shift at high rpms because your used to the longer shifts of your stock.. and that you should get used to just regular shifting until you have the flow down
works for me but also i noticed that if you park it in the driveway and just do a bunch of shifting without the car on it breaks it in pretty well also
Banned
04 STi WRB
Hi,
Make sure that the bolt is not too tight, you can back it off 1/2 a turn just to make sure. Also keep in mind that the shift throw is reduced by 40% so the effort will increase because of less leverage on the shifter.
Frank
TWM Performance
1 - 10 of 10 Posts
