99 OBS
The light that lights up the auto-shifter is out in my car. The light that shows P,R,N,D,3,2,1. Is there a bulb for this? Or several bulbs? How do I replace/repair this light?
Its pretty annoying at night, hard to see what gear you're in.
Thanks
2000 Subaru Impreza 2.5 WRXS
there are lights in it, just pop out the pieces around it and you will be able to get to it, i dont have any pics but its about a 15 min job, not too hard
www.jackstalk.com
Like everyone else said, theres a single bulb under there. I'd check fuses first. If it's not the fuse, then removing the trim requires a switch between removing phillips-head screws and carefully popping out plastic bezels, but the whole process should take under ten minutes to remove all the trim and get to the bulb.
