1 - 4 of 4 Posts
Hey all, was driving on the highway around 70 in 4th, was about to shift into 5th but hit 3rd instead. Pulled off the highway immediately, heard slight ticking sound. I was driving super gentle just trying to get it home when all of the sudden it sounded like something burst and now it sounds like a damn tractor. I have a video of what it sounds like at the moment. Anyone know whats wrong with it? If its fixable or if I need a new engine?
Thanks!
98RS, 98RS, 99RS, 99L
It sorta sounds like there's a hole in the header or the exhaust gasket blew a hole in it, but that's usually a bit louder. It doesn't sound like a knock. Maybe someone else has more info.
So you engaged third when attempting to engage 5th? So the engine over revved pretty hard then... I hear at least one cylinder very low compression. It indeed doesn't sound like knock, but there is no one home on at least one cylinder. lost a valve, hole in the piston, or hole in the block.
I love carnage photos, do update us when/if you find out what failed.
1 - 4 of 4 Posts
