Help me please
hi all!
ok heres my problem
car and mods:
99' 2.5 RS coupe @ 44k miles
PRM Ganzflow intake
Bruillen Full Header back exaust and hi-flow cat
JUN flywheel
ACT clutch
Denso Iridium plugs, stock wires
ok heres the problem:
the car was running AWESOME after i had the intake and headers/ exaust on. No CELs nothing, and i was beating my friends Probe GT with Mazda KLZE motor swap. I would spank him off the line and he wouldnt catch up to me untill around 90-100 mph. (it redlines at 8k)
then i got the car back after the flywheel and clutch were installed (this was months ago bear in mind)
and the car was misfireing HORRIBLY off the line. The car would literally rock back and forth violently. I drove the car like this not knowing what was wrong for like 4-5 weeks. Turns out it was the Bosh Platnum +4s i had on the car for less than 10k miles. the solenoid on (i think) plug for #1 cylynder was burnt off. so i changed them with some regular NGKs and the car ran fine again, however the car had lost a lot of power. Im talking not being able to keep up with the probe at all after 1st gear was done.
went on i-club and everyone said it was probably the 02 sensors, and by that time i had gotten a CEL. took it to autozone and it was the o2 sensors. since that time ive had them both replaced with aftermarket BOCSH sensors to save money. heh took it for a ride and there was a small gain in power, but still wasnt as fast as it used to be before everything started going wrong. i race a bunch of friends often and people that i used to beat or keep up with were spanking me. The car drives fine, felt fast, and i could only see the power loss when racing my buddies. couple weeks later, CEL for both o2 sensors again. Also, the car was idleing weird, hopping from just over 100 rpm (causing the headlights to dim) to about 800-900 rpm range. once warm, the idle wouldnt change as much,(maybe 400-500back and forth) but you can still hear the exaust note raising and lowering, lights dimming and coming back to life. I took the car to the same mechanic who had installed the flywheel, clutch, and the o2 sensors that were causing the CEL. He said that the car was running super rich, and that i might have burned out my cat because of it. So i tell him that its probably because i have an aftermarket intake and they are known to make the car run rich. Get home, start looking for an Apexi S-AFC so i can lean it out. what do i find out? that aftermarket intakes on 99s cause the car to run LEAN! the exact opposite of what i thought was causing the problem.
ok so what the hell is going on? why is my car running rich and getting bad MPG when its supposed to be running lean?
MAF blown? i never got it replaced for the recall.
could i have messed something up internally by driving the car for so long with a misfireing plug?
this is what im going to do after i get the S-AFC installed and tuned if the power doesnt come back
im gona get new Subaru o2 sensor front and rear, MAF from subaru, and new cat (if its fried)
think that will help? any input greatly appreciated
hi all!
ok heres my problem
car and mods:
PRM Ganzflow intake
JUN flywheel
ACT clutch
