1 - 7 of 7 Posts
No Subie to see here, carry on
I'm pretty sure this is somewhere but I searched and can't find it. Does anyone have a picture of this alleged hole under the brake booster to run wires through? I need to get an 8 gauge wire through my 95 and want to eventually add a hydrolic clutch and need to keep that plug available.
Please reply with picture as I can't seem to find it.
www.jackstalk.com
Its a rubber grommet right under the right aide of the brake booster if looking from the engine bay. From inside the car i believe its directly behind the brake pedal assembly. It really isnt that hard to find dude, its the only grommet that doesnt have anything going through it
Super Moderator
2000 RSTi
84956
You can see on my 2000 RS, it's below the pedals. The other side comes out underneath the brake booster
1995 EZ30 Coupe
The 95 does indeed have it, the clutch cable runs through it in the manuals.
84959
Like that dead pedal? I'm gonna make a new one I think.
Discussion Starter #7
So I had some plastic over the car to fix up some paint and haven't been able to look. I finally was able to look, and see a clutch cable going through the hole. I come on to reply and SoCoNoHa nailed it.
I'll just use the clutch master cylinder plug for now, leave the cable long so when I upgrade to a hydrolic clutch, I have enough for the new plug. Thank you everyone for the responses.
1 - 7 of 7 Posts
