1021 - 1040 of 2411 Posts
Turbo, LS swapped Impreza RS
Discussion Starter #1,022
Got rid of this for the price I paid 😂 and I'm holding out in pics of what's going on with the blue car. Stay tuned
Discussion Starter #1,023
Hey look progress!
Initial test fit confirmed there's some firewall cutting to be done but good news is the length is spot on with the shifter hole.
Discussion Starter #1,026
After bracing the body and starring at it for a bit, I worked up the courage and chopped into the firewall. I cut right up to the cowl and then 10inches from the center on each side. On the tunnel I only cut to the first seam because other than the bell housing the t-56 fits pretty nicely.
Mock up mounts tomorrow.
EJ205 1996 Brighton coupe
Interested to see where the engine ends up, specifically height. I was curious how high it would be in the engine bay if it was ABOVE the oem subframe.
Discussion Starter #1,028
My subframe sits at the same height as the OEM one but has about 6 inches more pan clearance. I'm going with a Canton front sump gto style pan so the portion over the subframe is only 3 inches deep. It will clear an un-cut hood.
