Build Posts:
UPDATE 1: Prepping the Shell
UPDATE 2: Chassis Completion
Jan 18,2010 - First Build Post
A little history: (feel free to skip past it)
BTW The date stamps on some of the pictures are incorrect, this is all recent.
I bought my 99 Impreza about 3 years ago. I went back and forth about which enthusiast vehicle to buy and given my personal needs and preferences ended up deciding on a GC Impreza RS. I found one for sale at a very good price at a dealership in Ohio. I made the 300 mile trek with a friend to end up with this:
It was the most money I had ever spent on a car and the nicest vehicle I had ever owned. I daily drive it whenever I can and autocross it on the weekends. I ended up doing many incremental upgrades to the chassis and engine. After always being down in power in autocross I decided that I needed to do a turbo build. I ended up pulling the motor and doing a turbo build from the ground up. Parts list:
First Build Motor:
Stock ej251 block rehoned
Stock STI pistons and rods
EJ251 sohc heads
CX Racing FMIC - piping remade to fit better
Bosch 1000cc injectors
FP td06 18g
NGK bkr7e plugs
Blow through maf using a wrx maf (how I finally ended up I tried many different ways)
Electrical:
Stock 99 NA ecu
E-manage Ultimate
J and S Safeguard
Prosport boost gauge, egt gauge, and UEGO wideband in modified center pod
Suspension:
Group N motor mounts and trans mount
Zeal Function Coilovers
I installed the motor then slowly began the process of trying to tune such a strange build. If you are considering doing a turbo building using your stock ecu please read this. A mild build with slightly larger injectors and a small turbo can be made to work properly but it still requires a lot of fine tuning and drive ability will without a doubt suffer. The more you change the harder it is for anyone including a professional tuner to tune. The tuning is long and tedious because you are constantly trying the ecu within learning limits along with a million other variables. The pressure compensation is almost impossible with anything other than a small turbo or hundreds of hours. You just cant get piggyback systems to function that smoothly. Idle problems boost, boost control, controlling huge injectors its all more variables in a very complex equation. Even with a proven build small turbo and injectors if you are a finicky person you will be disappointed. It will never run 'right' and when you try a radical build you end up in a worse position. The car never does exactly what you want it to do and you are always fearful it going to blow. I have been running various piggyback systems in various wiring schemes for over a year and I can tell you that you will inevitably end up swapping for more reliable and non-custom power if you try a piggyback build. My build never ran properly just okay. You might get lucky and you might get away with your build,for me eventually I was down on compression in a cylinder and the car ran worse every day. I decided to do it right this time and do everything from the ground up. This is where I am now.
End of the history lesson
I kept driving the car although it ran worse everyday and began my planning. My build plan goes like this:
-Buy a wrecked WRX and swap every bit of wiring possible, minimal wire merging, full dash swap
-The motor will use the heads from the wrecked wrx, forged pistons,and an STI 2.5 block
-While the vehicle is stripped for the swap take it further and take the body to a bare chassis
-Strip the underbody to bare metal removing all rust and properly repair rear fender rust
-Repaint engine bay,interior and underbody
-Install new motor along with the wrx wiring and dash, reinstall interior
-When summer rolls around repaint the exterior of the car aswell
A donor car is always preferred for a swap if not essential. You'll spend far more money buying parts separate and small little things will always be missing unless you get the entire car.
I drove out to Tennessee to pick up the wrecked wrx I bought, frontal collision but I'm not using the motor besides the heads so it doesn't matter. I bought it at insurance auction for an amazing price of $700 out the door. I recommend using a broker to find insurance auctions, I used a broker in Michigan for copart.com which allowed me to bid on insurance auctions all across the country. Direct from insurance auctions is without a doubt the best way to get a donor car.
Hey at least the battery didn't explode.
I brought it back to my shop and took my RS off of the road.
I actually had to cut the bumper beam and pry it out to get the motor out. The block was cracked, not that I need it, and the transmission casing was cracked, the gears should be fine but I need a new casing. Bummer considering I wanted to use it. I guess the stock RS trans will be going back in unless I find a new case asap.
Here it is after I got the dash out. I labeled each connection with blue painter tape and a sharpie, should make reassembly and merging easier.
Let the stripping begin!
Motor is out! I'll have to tear it down to check out that cylinder that was down on compression.
Interior and wiring removal.
Here is my parts storage, my shop is shared so I can't take up too much room. My shed is almost entirely full of parts at this point.
Chassis almost entirely bare.
I removed the sound deadener using the dry ice technique I'll try and get some pictures of it soon. The driver footwell had some good rust but nothing all the way through the floor just some pitting.
The sills by the rear wheels have some minor rust and the rear wheel arches on both side have some good rust going. No reason to scrap it though, my friend Dave who builds muscle cars is welding in new metal to repair it. Currently one side of the car is finished.
The easiest i found to remove the paint and rubber undercoat is to use a large grinder and wire wheel. Sandblasting hard to reach areas. The under body is stripped to bare metal right now. I'm trying to make the chassis even more corrosion resistant than the day it left the factory so epoxy primer over the bare metal is the name of the game then either rubberized undercoating like from the factory or a pickup spray on bedliner. Any help deciding which to use is welcomed.
Thats where I am with the car right now, a little more metal repair and some more paint stripping and it will be ready for paint. Remember the body exterior isn't getting painted until after the car is running again so the crappy black paint will remain until summer then its wrb time. The engine bay and interior are getting painted however, probably gray. I don't know if I should attempt the seam weld any of the chassis before painting. Where are the best areas to seam weld an impreza anyway?
The chassis should be ready for reassembly in a week or two. The block is already machined and I'm going to start building the motor soon. Any questions or comments about the build are welcome!
First Build Motor:
EJ251 sohc heads
FP td06 18g
NGK bkr7e plugs
Electrical:
Stock 99 NA ecu
E-manage Ultimate
J and S Safeguard
Suspension:
