1 - 11 of 11 Posts
01 RScoupe,02WRX
If the diff you'll be replacing is a 4.11 you should be okay. Don't forget to swap the bearings from the old diff to the new LSD. You can't mix up the bearings and races because they're mated to one another. Pull the bearings off by the race, NOT THE CAGE! I've wrecked bearings doing this. When your done don't forget to check the lash between the ring and pinion.
· Premium Member
overdeveloped beater
...and do not mix up the little shims that are on the sideplates.
Clean everything really well and doublecheck the wear pattern with grease before you put the cover back on for good.
Don't overtorque the sideplate bolts, or you may throw off the backlash.
Take your time....it is the easiest way to add an LSD to an open diff.
· Premium Member
Good advice on rear pumpkins. :)
I had always wondered if Subaru used shims or adjustment nuts.
They actually used both. The T-type uses shims and the VA-type uses a star shaped adjustment nut....just like the front diff. Both are still considered R160s, but not much is cross compatable betweeen the two.
2007 impreza 2.5i
Discussion Starter · #8 ·
sorry hahaha more info would have helped. Uh its a 98' impreza outback sport. it has 3.90 drivetrain. so is that possible? all I want to do is take the LSD and put it in my diff.
· Premium Member
Yup...exactly the way you should do it. Pull both diffs out of the housings, swap the ring gears, and put the LSD into your OBS housing. While it's always good practice to change the bearing races to keep them with the bearings that originally came with....I've found the Subies to be pretty damn tight on tolerances......tight enough that I've had to make a change in 1 diff out of 6-7 that I've done.
Check things first, change if necessary.
· Premium Member
95 L, 96 OUTBACK
Yep I kept my bearings on the carrier. Went just fine.
1 - 11 of 11 Posts
