So I'm in the process of replacing my slave cylinder due to my clutch pedal getting a little soft after 15 mins of driving.
My main question I have and did not find while searching on this site is; is there any adverse affect if I just replace my slave cylinder and finding out later it was the master cylinder that was bad? Basically saying if the master cylinder is the culprit of my soft clutch pedal, will it ruin the new slave cylinder I've installed?
I rather spend the least amount of money possible to fix this issue and it seems by statistics the slave is the one that goes most of the time and if that didn't fix the problem i would then replace the master cylinder.
Thanks everybody!
Thanks everybody!
