1 - 6 of 6 Posts
99 2.5RS BRP
I searched and didn't find anything about relocating the A/C controler... I want to know if I am able to move my A/C Control all the way to the bottom (usually where the headunit sits) The reason why I am asking is because I want to put a double headunit in and I don't want my shift knob to be blocking the screen. Also I don't want to be doing alot of modification...like the most modication I would really want to do is cut out the bar and probably extend the wire to make it fit all the way down.
1998 impreza 2.5rs
weird, I sorta asked a similar question on...the other site...it's related as to which wires control the a/c and maybe controlling it with a toggle switch elsewhere. I just posted it today, but if someone answers on...the other site...then it might be some usefull information. here's the link...
http://forums.nasioc.com/forums/showthread.php?t=1273834
...and then I looked at your profile and saw you have a different year than me, so this may be of no use to you at all. in that case sorry.
2000 RS
Do you mean somethign like this?
This is going to house a 7" VGA touchscreen on the top for the CarPC and the AC controls will be at the bottom. So far I have not seen anyone that has done this, so I might be the first one to do so for a friend of mine.
What I did was cut the entire AC and double din area out and flip ip upside down. Then, re-glue everything into place, fill, sand, etc.
The pic shows the first stage of primer, so more is needed. I'll post pics of the finish product once it's done.
1999 SUBARU IMPREZA RSTI EJ20K
yes it will be fine and work atleast on my rs i did it and it was fine.
1 - 6 of 6 Posts
