1 - 9 of 9 Posts
1997 Subaru Impreza
94 gc6 rear disc conv. Would like to install 97 legacy rear discs. I have the calipers and rotors. What else EXACTLY will I need?
If you have drums in the rear originally, I think you'll need to do a hub conversion as well.
I have a '97 L. Rear drums in the rear. Had to swap out the hubs in order to convert to disc brakes.
1997 Subaru Impreza
Ebrake line, umm i think... and yes the hub conversion... i did a rear disc swap conversion too! swapped out my 93 drums for 98 rs pots.
Ebrake line is really up to you. Uh... There are really two ways to go about this. Both are a pain in the ass. One way is to totally replace the ebrake lines. Pull out the interior, detach the old lines and attach the new ones. The other way... You can reuse your existing ones, but you have to take apart the old hubs to detach it, and when you put the new one on, you have to reattach the ebrake lines. Yeah... tough choices...
1 - 9 of 9 Posts
