Ok this is the deal, its a 97 OBS with 211k on the clock, runs like a champ almost all the time, I think I figured always runs great when its dry and only sometimes when its wet.
It started last winter, i was on a 3 hour road trip around hour 2 the car started sputering without a check engine light. it started slowly though a hicup ever min or so , then it just gets worse and worse until it got to a point where it would barely idle (finally a check engine light came on). I pulled into a parking lot and looked under the hood, i knew there was an autozone down the street if i could limp it there i might be able to figure out what is going on. But i needed to find out how to get it there. So I start tinkering with wires and checking to see how it run and such.
Finally I disconnected the battery for a few min, reconnected and it ran well, so i got excited and jumped in to head to autozone. I was a 10 mile drive to autozone, it didn't skip once in the ten miles and the CEL had gone away. So I kept driving past the autozone and around 30 miles past AZ it started the whole thing again. so i pulled off disconnected the bat for a little bit (10 min or so) and made it the rest of the way without any problem.
This series of events happened randomly through out the winter and each time i disconnected the bat for a short period of time and usually it would run as it should for the rest of the trip.
The only time I ever get a CEL is when it skips so bad that it has a hard time idleing.
The car had around 200k on the clock when all this started and ive put another 11k since then with this stop and fix routine. Its made countless 8 hour trips without a problem.
I have looked under the hood and under the car for exposed wire that would cause this to be affected by water, but that doesn't explain disconnecting the battery to fix it and drive in the same conditions and for it to run correctly afterwards.
I appologize with the long post but I feel its valuble information to describe my situation, if you guys can help it would be appreciated before i start throwing parts at it.
Thanks,
Pete
Thanks,
Pete
