1999 Subaru Impreza GF8 Wagon
Hi, I’ll keep it short and sweet. Looking to raise the motor on my gf8. Is this a possibility or am I stupid? Any links to threads already created by this? Thanks much.
Why exactly do you want to lift the motor?
Raising the motor wouldn't do anything for ground clearance as the subframe is still mounted to the unibody. You can raise the body and suspension mounting points to fit larger tires which would earn you some ground clearance. Another option is to use forester struts/springs but this will throw your geometry off and you'll need to space some things anyway. Are you looking to build an off road rig?
Discussion Starter #5
Ah, yes that makes sense, didn't even consider the subframe. I do have a new project I plan on going on. Appreciate your help.
