1 - 6 of 6 Posts
2.5 rs
Discussion Starter · #2 · (Edited)
Complete Long Block
2.5 L Shortblock:
CP Pistons (Stock STI Comp.)
Carillo H-Beam Rods (1200hp)
NEW OEM STI Crank
ACL Bearings
2.0L Heads:
STi Cams
arp h11 head studs
Killer B Motorsports Oil pick up
NEW OEM Oil pump
AN Fittings for valve covers
NEW Gates Racing Timing Belt Kit & Water Pump
Motor has 2 hours
$4000
2.5 rs
2004 WRX 5MT TRANS
PPG Torsion Front Diff
PPG Billet Shift forks in 1/2 3/4
1st gear- 06 wrx
2nd gear- 06 wrx
3rd gear-PPG Helical Cut
4th gear- PPG Helical Cut
5th gear- 06wrx
Custom High Strength Bolts through out for case strength
Axles stubs out of trans
Kartboy Short shifter
TiC Pivot Bushings
$2500
2.5 rs
Discussion Starter · #4 ·
5x100 AST 4100 Custom Valved 12k front swift springs 11k rear swift springs
Noltek Front Camber Plates
Vorshlag Rear Camber Plates
$2000
Whiteline 22mm STi Front Sway $100
Whiteline 24mm STi Front Sway $100
Whiteline 27mm Rear Sway $100
Cobb 25mm Rear Sway $100
05 WRX Front Knuckles $150
STI Rear Subframe $150
Please give me a day or two to complete my FS threads and ADD pictures
1 - 6 of 6 Posts
