1 - 9 of 9 Posts
1999 Impreza 2.5rs.
I am about to upgrade from 16" goldies rims to 17" rims. When I get new tires, What size tire wall should be good to keep from rubbing. Stock tires are 205/55-16. Would 205/50-17 keep the overall size roughly the same or should I go smaller?
Free!
01 RSTI / 03LeggyH6
I personally would go no more than 45 sidewall on a 17. But it really depends on the owner. Depending on what offset wheels you buy, your ride height and suspension setup (coilovers vs struts) a 205 with a 50 sidewall might work and not rub the fenders on the outside but it could very well hit the strut/spring perch on the rears on the inside. I think with a 205 you should be OK but since I never ran that size tire I cannot be for sure so again I would play it safe and go with the 45 sidewall, also with a 17 you could go wider with a 45 like 215 or 225 and be OK.
1999 Impreza 2.5rs.
Discussion Starter #4
thanks for the help!
Baby❤Daddy
98L Wagon
it also depends on the amount of 'low' you want to achieve. i'm on 215.40.17, and they just barely clear the fenders, and make the gap nice and tight.
**** cell phone pic...but you get the idea.
Hoopty King
2000 BRP 2.5RS/1994 Legacy SS
I've always run 215/45/17 on my cars, and have recommended other GC guys I know to do the same. More width, pretty much the same sidewall height, and honestly they look better and fill out the wheel/tire package better, IMO.
Only time I've had rubbing issues with them was on a set of +38 offset wheels with no fender work.
1999 Impreza 2.5rs.
Discussion Starter #9
If you're going to sell the Goldie's, let me know...
Sorry, they are painted 5 spoke aluminum. not the real deal.
Thanks for all the help guys. !!!
1 - 9 of 9 Posts
