I can't seem to be able to remove the old axle shafts from the hubs in the rear. I was gathering all the parts from a legacy for a rear disk sway when I ran into this problem. I had the hub completely off the assembly but couldn't get the axle to pull out. I even had the outer nut off and still nothing. I tried a axle puller from auto-zone but it couldn't push it out either. (using all the torque I could with the hub not on the car anymore which wasn't very much.
My qusetions are as follows
1)- do I even need to remove them or are the 98 legacy ones the same lenght as my impreza ones?
2)- why wasn't I able to get them off in the first place? Is there some sort of pin buried inside the e brake housing that I cannot see. Or is it just being a stubborn 10 yo SOB!
