1 - 20 of 580 Posts
2000 SUBARU IMPREZA OUTBACK SPORT
02 Wrx longblock
TVG Delete
Grimm Speed EBC
1 step colder plugs
Invidia Catless up pipe
Turbo XS 4inch catless Downpipe
Group N Motor Mount
K&N intake
oil cooler/warmer delete
killer bee oil pick up
2.5 oil pan
no name UEL headers
no name inlet tube
SS clutch line
Exedy Oem clutch
Exedy LWFW
VF23 (waiting to be installed)
650 DW injectors (waiting to be installed)
09-14 wrx/sti hatch SPT cat back.
Driveline / Suspension / Brakes
4 pot front brakes with DBA 500 rotors, and HPS pads
2 pot rears with KNS gravel spec rotor with HPS pads
Hydro ebrake (waiting to be installed)
Cobb SS with 3 inch TI extender and hurst pistol grip shifter
kartboy/subimod F+R Bushings
Ebay Strut Bars
05 WRX Cross Member with control arms
05 steering rack
Group N Tranny Mount
STI 20mm rear Sway Bar
22mm/24mm front Sway Bar (depends if on dirt or tarmac)
Whiteline HD Endlinks
Rear Disc Conversion
Braided Brake Lines
Extended studs (waiting to be installed)
Muteki lugs (steel)
Wheels
Method Rally wheels 5x100 15x7 offset 15
RS 6 spoke wheels with what ever tires
Firestone Winterforce 215/60r16 depending on my mood - Winter
Looks in
JDM V3 STI front seats
04 wrx center console
Suede wrapped dash
11 WRX (type C) radio
Boston Acoustic SX65 speakers
Forester Dual Cupholder
NRG 3inch deep dish
NRG Quick release
NRG shorty Hub
V5/6 STI Cluster
Looks Out
22b Sport Bumper Replica
Cf STI hood scoop
headlight shroud painted
Amber corner markers
Thule Roof Rack - Board adapter - Bike adapter
2 Hell 500 fog lights yellow tint
2 PIAA 520 Ion fogs
GF8 replica wing
JDM Roof Rails
Snowboard straps holding on the bumper
Skid Plate
Discussion Starter #4
no snows (repeat i know)
FINALLY FINISHED my hood Scoop
plate covers
testing
under side
top
Center console
old
changed the bracket
trimmed the sides not bad for not knowing what im doing....
BAM 04 WRX center console in a 00 OBS
luckily i had 2 to work with.. cut the first one wrong...
then broke some pins holding on the shift boot so i improvised
BAM BAM BAM!
1998 2.5 RS, Brilliant Red
you didn't like the rubber accordion thingy ? ;)
new center console looks great, man !
Discussion Starter #11
wooot just won 2 tickets to WBM!!! thanks to Subaru of New England
Discussion Starter #12
here is a short install photo sesh of my new to me 2011 radio
So as most know i got a 2011 wrx radio from Grestch
dont it look purdey
the issue i ran in to was this newer radio has the new 20 pin connector and my car had the older 14 pin... so with some research i found
THIS web site Subaru radio and radio wiring harness information (david) he makes harness for subarus. check out the parts list he can make ae64.com - Subaru Radio Wiring Harness - Order Form
I had him make the correct pin to pin connector with extra wire for the steering controls because i plan to put a wheel with controls in at some point. So those wire will sit dormant till then...
while the face of the radio look larger then a normal double din the body is normal sized... SO it fits in the regular radio slot
It fits in nice and tight
Had to trim the molding so i took some tin snips and cut little sections out at a time to not mess it up too much
Then i took my bigg ass cutting blade (only thing i had) and cut out the sides and lower area so the radio would pop threw
Not the prettiest thing but it does the job
All put back together
every thing works good.. just need to get the usb cord and il be good to go...only issue i have is during the day i can not read the display that well due to it being lower then where it would normally sit.
other then that its running well next to do it update the speakers to match the quality of the radio
Discussion Starter #15
Ebay strut bars
[/IMG]
and just ordered Clear Corners - Euro style
Discussion Starter #16
OOOO FANCY
Moar Lights - Hella 500 FF
Look at that size!!!
Factory
Not so Factory - Could not wait had to test it out!
Needs a good cleaning i bet this is the first time off in 12 years
Discussion Starter #18 (Edited)
few weeks ago i picked up a set of boston acoustic SX65
picked up the usb wire for my radio yesterday and installed it today
also picked up my 09 sti mid pipe one step closer to putting in my 09 quad tip
Discussion Starter #19
Tradeing a set of 98 outback rims with 97% new winterforce rims for a set of these tomorrow... they clam to be uncurbed... so time will tell
1 - 20 of 580 Posts
