1 - 20 of 32 Posts
2004 Forester XTi
It all came down to a loss of oomph higher in the rpm range, so I decided to do the mod to the air box (Ganzflow stage 2 purchased at Menard's for around $25). I got a flexible rubber 3" 90 degree sleeve that fits perfectly over the Ganzflow and attaches to the box. The work doesn't look too professional, but the flow is so much better comparing the stock arm to the new 3" arm. I used 'J B Weld' as the adhesive. Awesome stuff that hardens in a few minutes. I also used the Dremel tool (35000 rpm) to free some air space in the airbox webbing. I'm sure that helped a bit.
The pull is strong as usual lower in the revs, but the top end is much better than I remember. I was WOT the whole way to my bro's place and I loved the feeling. It felt that I've gained 5-10 top end hp! I own a G-Tech so I'll be posting some numbers soon. Before, I got a 0-60 in 7.4 secs and 1/4 in 15.71... I'll have to find a spot to test it out without disturbing the peace. :) Vroom Vroooom VRooooaaaaaarrrrrrr!!!!!!!
2004 Forester XTi
Discussion Starter · #4 · (Edited)
Here are the pictures. I think this helped more on the top end since it is 3" from the Ganzflow to the throttle body. That stock arm is puny and has the 4-5mm plastic from all around the lip restricting the constant current of airflow from the sides coming from the ganzflow. Sorry for I have no hard hp numbers, but butt dyno feels a bit stronger. FYI, the Ganzflow fitting perfectly inside the rubber arm = no air restriction.
2004 Forester XTi
Discussion Starter · #6 · (Edited)
Here's a closeup of my JB Weld and where I placed the 90 degree arm and the 3" plastic connector plate connecting the rubber arm to the box and my dremmeling with the 35000 rpm tool to take out the restrictive webbing inside and the foam caulk I put inside to allow the air coming in the box to kinda stay in the middle of the airbox. Whew!:)
Would I do the mod again? I'll just say I was gonna cry like a baby when I got the restrictive arm off. I didn't know if I had the skills to finish the project... I felt sooo relieved once I did. Whew!!! :cool:
2004 Forester XTi
Discussion Starter · #9 ·
Allllllllllrighty-then... Pics, pics, pics. Two of 'em.
Ummm, about the koozie. Ummm, the store ran out of them. Ummm, yeah. That's right! The store ran out. Once they get more koozies, I'll finish up my full CAI and be :happynow:.
2004 Forester XTi
Discussion Starter · #12 ·
RageHardIntoTheBendies said:
Look svery similar to mine exept I used a solid Elbow
By the way I have changed my Hose clamps since this :D
This Mod really compliments the UD Pulley too.
How did you get the solid elbow to fit onto the airbox? I mean, the back of the box gets thinner and thinner and the solid 3" won't get any smaller. I pinched my pipe a little as to not allow a gap from being present around the area I cut, and then I JB Welded it into place. How long have you had it?
What I did is cut a 2-3" Long Piece of 3" ABS Tube and cut about a 1/4 of it away, if you piture it bonded to the elbow it would protrude 2" out of the end and the gap would be on the front portion of the elbow and box. I then carefully removed the "Thin" part at the back of the airbox until it mated nicely with the new pice of tube. Then I just sealed it all up with FG.
Ok Yea Doesent make much sense right ?
Look at the crude diagram below the red section would be the 3" tube piece and wraps around to flat part of the underside of the box.
Hope that makes some kind of sense.
I did the 3" ABS (Home Depot) mod earlier this year and the custom fitment of the 3" pipe to the air box was the toughest part. This definatly made an improvement...I can keep up with the wife's 02 SRP WRX until she hits 80...then I start loosing ground.......
1 - 20 of 32 Posts
