1 - 9 of 9 Posts
2001 Coupe
My baby has sat for too long. I simply don't have the time to care for her anymore. Time to pass her on.
https://www.rs25.com/forums/f145/t176049-jonny-os-2001-rs-cursing-crude-humor-flying-ball-bearings-inside.html
Please see the build thread for specifics. You'll have to have the chrome extension for photobucket images.
The short- I put all my effort in the motor. It's a blueprinted pump gas screamer. The body shows age with quarter rust and peeling clear. Drivetrain is stellar.
Has tons of goodies from myself and previous. Well cared for car.
Scan through the build thread and feel free to ask any questions via [email protected].
Asking 6k including 1100 in brake, strut and bushing parts yet to go on and random spares.
2001 Coupe
Discussion Starter #4
Started her up to take her around the block and the header is toast.
Don't have the time to fix.
$4k takes her. Priced to move.
Can you send pics to [email protected] ? I’m having issues viewing the pics even with chrome for some reason...just would like to see outside body, engine, interior pics. Thanks if you can!
2001 Coupe
Discussion Starter #8
Damn photobucket.
Will get some pics coming.
Rarely here due to work schedule, so please feel free to email me (not PM) at the address in the first post and I'll get you my phone number to answer any questions.
From a post in 2013 if anyone isn't interested in digging through the journal:
UPDATE: The list.
I was thinking about my to-do list and decided it was time for one of these.
-10.55:1 2483cc ej251 Up from 9.89:1 2457cc. I think.
-Extensive head, intake and throttle body flow work with lots of fresh OEM parts. MORE INFO HERE FLOW BENCH WORK HERE AND MORE HERE
-One-off port-matched Teflon intake manifold spacers. MORE INFO HERE
-Delta 1500 regrinds.
-Balanced rotating assembly.
-Whitchhunter flowed injectors.
-Ceramic painted intake manifold.
- SRS-30 I speed reflash (to go in after updates)
-Exedy lighter flywheel and “stage 1” clutch.
-AEM warm air intake (to swap for Ganzflow in the spring)
-Genuine Borla, stock cats, 3 inch catback and watermelon shooter (to swap for scoobysport asap)
-One-off crankcase oil catch can. MORE INFO HERE
-07 wrx rear sway bar.
-03 wrx wheels, wrapped in Continentals .
-One-off DIY super tall short throw shifter.
-RalliTec plug wires.
-DIY Grounding kit.
-Buurma racing light bar and Hellas.
-Amber corners.
-JDM rear spats.
-JDM flat fuel door kit and JDM fuel cap.
-04 wrx black on black seats front and rear.
-03 wrx wheel.
-Rally Armor rock stoppers.
-OEM in dash NAV setup. (Swapped for full sweep mechanical gauges)
-Stainless brake and clutch lines.
-Old school Visteon Radiator. One-off over engineered catch can.
To do list:
Finish cat pipe.
Trans removal – Swap lightweight Exedy flywheel for lightened stocker.
Replace stock trans mount with Group-N
Install new exhaust.
Reflashed ECU install.
Install Gary’s Garage purchased “cheap strut bar”
Possibly use drivers side for home made master cylinder brace.
Possibly use passenger side mount for mounting Barbie catch can.
Finish one-off intake including torquebox/Ganzflow elements.
Decide between h6 and wrx rear brakes and do a swap on all 4.
2001 Coupe
Discussion Starter #9 (Edited)
Car needs to move. Interested party dropped out. I took a series of text sized videos and can send to those interested. Running out of time for tire kickers, as I'm losing my shop space. Text me at 419-706-6665
4k. Priced to go. That price gets you the built motor and everything else is for free.
1 - 9 of 9 Posts
