1 - 6 of 6 Posts
2001 2.5RS SRP sedan
Is positive camber in the rear normal after lowering subarus or would something else be wrong? I lowered my car (01 2.5 sedan) about a year ago (kyb adjustables, p1 springs, also have a wrx sway bar and solid end links) and never really paid any attention to tire wear until recently when I noticed that the summer tires I bought for my car and put on this spring are super worn in the rear on the outside of the tire (passenger side tire being worse than the driver side). The fronts seem to be fine. Did some research and didnt really come up with a definitive answer.
'00 2.5RS Coupe AW
You usually get negative rear camber due to the geometry of the suspension when you lower your car. Never heard of positive rear camber after lowering.
1 - 6 of 6 Posts
