1 - 4 of 4 Posts
I have a 01 2.5 rs with an automatic trans, and it accelerates painfully slow. I have measured the 0-60 and it is consistently around 9.8 seconds, and I’m pretty sure it should be around the low 8s. I was going to do a full tuneup on it (spark plugs, wires, etc) but what else could possibly be causing this and what are some solutions?
www.jackstalk.com
Put a turbo on it!
Honestly it can be a huge variety of factors with the little information you've provided. Anywhere from the brake calipers sticking all the way up to an electrical issue or sensor malfunction.
Put a turbo on it!
I know it’s not the calipers and I’ve had the major sensors tested and the wiring has been checked due to past issues
2002 WRX
As was said, could be a slew of things but:
1. bad plugs / wires
2. bad fuel
3. bad timing
4. bad / clogged injectors
5. transmission slipping
6. clogged fuel line / filter
and that's just to name a few things
1 - 4 of 4 Posts
