1 - 12 of 12 Posts
This is about a motor that had rod kock so I'm just curious.. on a EJ25 cylinder #2 at TDC I'm able to press the piston down and it also has a thud sound associated with it, so is this on the crankshaft bearings right? I wonder if the block could be saved? I know the crank most likely not.
The subaru of many acronyms
probably bad conrod bearing i tore apart a ej205 that had similiar issues as what you described, every crank, and conrod bearing was toast a few had spun and welded them to the rod itself crank was done rods were done. so if you wanna rebuild that motor its possible the block is still good, but for the amount of work that will need to be done/amount of new parts required your probably better off finding a new/lowmiles shortblock.
Discussion Starter · #7 ·
I wonder if it's worth putting a ej22 crank in a ej25 block? I do recall that one of the years the thrust bearing moved positions and I'm not too sure where the changed happened.
1 - 12 of 12 Posts
