1 - 9 of 9 Posts
i have searched and searched but i have not gotten a really clear answer.
if i used the perrin uppipe would i have to swap my crossmember?
thanks
ok thanks, one more question i know i asked this in another thread. for a home made turbo kit, a crossmember is the only suspension part from the wrx i need correct? no control arms or sway bars?
aka RFoy2.5RS-T
98 RS
You'll need a turbo front sway bar and you'll need to shim your control arms with washers other than that you should be set.
02 WRX
hay i want to know would a perrin up pipe clear Phase2 RS heads with a wrx/sti cross member swap on it as well.? im thinking of getting one but dont know if itll clear my heads.
Anti-Nonsense
2004 2.5 RS, 1973 L48 Corvette
EDIT: Misunderstood your question. My bad. I am pretty sure they will clear. Dont quote me on it but I believe it was the Phase 1 heads that couldnt be cleared without offsetting the up pipe.
1 - 9 of 9 Posts
