2005 forester
Scanned my CEL and it had 7 codes: p1510, p1512, p1514, p1516=iac valve circuit low input 1-4
P0420=catalyst efficiency below threshold
P0440=evaporate system malfunction
P0108=pressure sensor circuit high input
I listed all the Codes in case it effects the one I'm wondering about.
The only one I'm confused on is the p0108, mainly because my car a maf sensor and the code I believe relates to a map sensor.
I reset the ecu and plan to drive it till any codes come back on but does anyone have any idea what's up?
00'RS/02' WRX stgEleventy
My 02 has both MAF and MAP.. the MAF is on the intake and the MAP is on the throttle body..
Its part of the throttle body on mine, so its right next to the IACV and TPS
Not 100% sure on the 99 do a google
2005 forester
Pic of my intake mani. Seen a pi of where it would be and it's clearly not there.
On another note, CEL's haven't come back on yet, though I know 2 will be coming back for sure. I'll just have to see if the iac and the map sensor one come back
