OK so ill start with,1998 legacy gt limited. ej25d. 2 weeks ago i replaced head gaskets, thermostat, water pump, timing belt, all associated pulleys and gaskets. Then drove it for 4 days and it ran great then out of no where it over heated. So wtf. Its going through coolant like crazy. After the first time it over heated now every time i start the car and go to drive it over heats. Ok so i tried to put a vacuum on the coolant system and it would not allow any vacuum. I put pressure into the coolant system and it did leak out very slowly.
So sunday i pull the engine, cylinder 4 was full of coolant. Head gaskets look fine. They were deff sealing you can see from the ring where the gasket was pressed against. So uh. WTF!? could the intake be cracked and coolant dumping in and onto cylinder 4?
Someone please help!
Oh i did test the thermostat and it worked fine!
