I did this and the crank keeps spining...wow overcomplicated batman!
Get a long ass bar on your breaker bar, leave it in gear or park or something and just pull.
comes right off.
That wont work in an automatic...wow overcomplicated batman!
comes right off.
just do this.... it waaaayyyy safer than using a starter and a 2 ft bar.there is a hole in the block about halfway down on the passengers side, it very close to the bell housing, where the tranny and engine meet. looks like a bolt hole... stick a flat head in there so it meets the flywheel, once its in, get tension on it with the breaker bar on the crank (22mm not 23) and you can do it that way. its way safer...
YES pic please i cant find were to put the screw driver atstick with it... thats all... if you need a pic i can get one...
