1 - 10 of 10 Posts
Well I was driving around the other day and noticed that my oil pressure gauge was reading very very low - at idle is reads 0.... but the engine sounds alright, no knocking, no abnormal/unusual ticking. Then at WOT, it slowly rises to 20psi. This was done all with the engine warm as I noticed it once I was on the highway for a good 30minutes.
I started it up this morning and at cold idle it is only 40-60psi max. I read that it should be higher when cold. I did not drive it today as I do not wish to hurt the new engine.
It has a new sti oil pump, and all new seals/gaskets. This is on my ej257 engine. There are no leaks anywhere. My oil pressure gauge is one from advance auto - sunpro I believe. It has the copper line going to it and I have it tapped on the back of the block, passenger side.
Could my pick-up tube be clogged ? I cleaned it out when I built the engine, so I do not think its that. Any ideas/suggestions to try? I am open to anything. I do not have another oil pressure gauge to test - this one seemed to be working fine, and its only 5months old (give or take a month).
Please - any suggestions? I will be pulling the engine out to check the oil pan, and pickup friday night - but would like other suggestions, that can easily be done in a day while I have the engine out.
overdeveloped beater
check for a leak at the connections. They aren't of the best quality....and you only get one good shot at making them seal.
2015 WRX
If you have zero oil pressure the oil pressure light in your cluster will come on. It sounds like from your description there is a clog somewhere in your feed line to the gauge or the gauge itself is broken. The oil pressure should change very rapidly.
I'm in VT and have a spare autometer gauge... I dropped it a while ago so it reads 20 psi off, but the needle actuates as it should... if you're interested in using it for testing let me know.
Discussion Starter · #4 ·
hey suby25 ... yeah -- that would be very helpful, like I said ... this has me pretty stumped as the oil light is off, and goes off after like a second of two when first starting - and it stays off while the car is running. Also the copper line is brand new, just bought it sunday and installed it yesterday - it had the plastic stuff ... crap .... so im down to either the gauge or the pickup.
Suby25 -- where abouts in VT are u located ?
also --- when the gauge pressure changes, its not a fast change, but it moves slower then i would think -- like it doesnt spike right up to the pressure. and on the throttle it doesnt really move once its warmed up.
2015 WRX
Replied to your PM.
My oil pressure gauge changes pressure very rapidly. It will rise from 30 psi at idle to 60 psi just with a blip of the throttle.
Did you use teflon tape on any of the fittings? Perhaps a piece is lodged in the oil feed line somewhere?
Discussion Starter · #7 ·
no, I used some pipe dope stuff that I use at work - propane technician. I checked the oil passages and they seem fine where I tapped for the oil pressure gauge. I am gonna take the oil pan and the oil pump off this weekend. Maybe some of the RTV got stuck somewhere - or maybe the pan isnt sealed good (altho I did use a good amount of sealant).
'97 Emerald Green GF4 5spd
Hey Vipergtrdj, Im not sure if this info is any useful but when at cold start, I notice that my Oil Pressure is always at 80 PSI then as it gradually get warmer it would drop to until when at normal operating temp. it fluctuates between 15-20psi.. From my understanding that anything below 10PSI is bad.
GL
Discussion Starter · #9 ·
yeah, I am gonna pull the oil pan off and check the screen on the pickup tube. I am also going to pull the oil pump and check the o-ring gasket that is on the back of it, maybe it got messed up when putting it on.
I changed the gauge and it reads about 10psi at idle, and it is around 40-50psi when on the gas. Still not that high, but better then the other gauge was reading.
2015 WRX
Is this a turbo motor, or just a 257 shortblock with NA heads?
FWIW on my EJ20G, I see 90 psi at idle from cold startup, 95-100 psi while cruising while oil is cold. Once the car is up to temp, 80 psi during cruising and 30 psi at idle. I would expect lower oil pressures for NA motors.
A friend of mine rebuilt his 257 and forgot the o ring gasket on the oil pump and blew his motor on the dyno. Air was getting sucked in and mixed with the oil and he spun a bearing due to low oil pressure. I guess, as you mentioned, that could be causing your problem.
Good luck figuring it out, hopefully no damage was caused.
1 - 10 of 10 Posts
