This is great i'm looking forward to even reducing the rattle to just a little bit of noise right now my obs rattles like crazy and driving me nuts
what did you type in for your ebay search... having troubles finding anythingI just picked up a set off ebay for $10 shipped
Hella stoked to get rid of that rattle lol
Will do lolSweet thanks for the link. I will wait for you to report back before I buy.![]()
So I forgot to post pics and my results but here they are...
My rattle did not go away lol, it just shortened the rattle time and made it more frequent but it never made it go away, just quieter. Which isn't a good thing or a bad thing i guess, i am going to adjust the striker plate and see if that can effect the vibration.
I am down, just let me know lol.we should meet up and compare rattles. I think some come from the latch, and others from other parts in the rear. I am going to see if I can more easily engineer an alternate plan using similar parts. But this plan will probably involve cutting and or drilling.
Went to adust the striker this weekend and found out it has been pushed all the way down.I am down, just let me know lol.
I think if you cut and drill and be able to insert the hood bumpers it would work really good.
And then you could screw them in and out like you do on the core support to adjust to the perfect level.
But i wanna stress that i have not adjusted the striker, i will attempt that this weekend and see if it is better.
How about next weekend? (where you at?)Went to adust the striker this weekend and found out it has been pushed all the way down.
Grounded the hole a little bit longer and now no more vibrations!!!
I am in white salmon wa, like right across the river from hood river in the Columbia gorge.How about next weekend? (where you at?)
I was thinking of trying to make work the adjustable one that the newer wagons have. But it would mean a little bit of work.
95% of my rattle went with the two rubber pieces, but there is still a tiny one.
But since every car is different, it might work better for some, but not others.
I also adjusted the striker all the way down. But another cm of movement would pretty much fix everything (i think)
Now someone needs to come up with a dash rattle fix....
