1 - 4 of 4 Posts
Ok so I have oil leaking from that area. Got the OEM o rings. Took the two 12mm bolts off. Now the plate won’t remove. It move up and down some but won’t pull off. Does it come straight off ? Or is a locking situation where you have to turn it one way to pull it off? Would it be safe to wedge a flathead in there to pop it out? Let me know what you guys have done. Thanks
Super Moderator
2000 RSTi
you might have to tap it one way and then the other, over and over. It does come straight back out. I wouldn't recommend anything more than gentle prying since you could crack the holes the bolts go through.
Thanks that’s what I did. And I came off 👍
1 - 4 of 4 Posts
