1 - 6 of 6 Posts
89 RX-7 TII - 05 2.5rs
My parking lights wont turn off only while the car is on. I have the DRL switch unplugged, the parking light switch turned off, but they stay on along with the dash lights that are controlled by the dimmer switch. My headlight switch could be completely off, yet Im still able to control the dimmer lights too as if the headlights were on. I dont know what else to do to fix this. I dont want any of these lights on while Im driving unless intended to.
Have you tested/replaced the head light multi switch?
Quick peek at the wiring diagram, power goes through the parking light switch, to the multi switch, to the relay. so it could potentially be a bad parking light switch as well.
Discussion Starter #5
Now that you mention it the parking light switch could be it. I tried switching it on and off before and it did nothing at all. Ill test it out or replace it and see if that does it.
2.5RS, STI, BRZ, ZL1 vert, X5D
Now that you mention it the parking light switch could be it. I tried switching it on and off before and it did nothing at all. I'll test it out or replace it and see if that does it.
Did that fix it? I'm having a similar issue.
1 - 6 of 6 Posts
