1 - 4 of 4 Posts
2002 RS
My car will not start, and it will not crank. This all happened a day after my clutch master cylinder went bad. I redid the lines and the master and now my clutch has pressure again, but now it won't start. The battery is fine and the sensors are all plugged in. I checked the stock alarm setup and it's not disabling the car from starting. I want to check the clutch safety switch if it blew, other than that I am at a lost. Any ideas ?
2002 RS
Discussion Starter · #2 ·
Anyone ? I checked it and it's working fine, so I am slightly at a loss. Starter has power but is not cranking meaning something has to be preventing it, the fuel pump also isn't turning but the ecu appears fine and the alarm isn't enabled.
overdeveloped beater
Check the small wire on the starter to make sure it hasnt been knocked off on accident. Then check all the battery connections at either end. Connections need to be clean and tight.
1 - 4 of 4 Posts
