Hey guys, I tried searching, and didnt find anything.
Here's the issue:
I recently had a local shop install an ACT street clutch, and lightned flywheel. I also flashed to XPT tuning's stage 2 map. I'm finally done with the 500 break-in miles, so i did a few WOT pulls. Everything seems fine, other then the RPM's jumping a half rpm when i shift, also when drifting to a stop in neutral, somtimes the car stalls.
So, do you think this is a clutch/flywheel issue or a reflash issue?
Thanks
Here's the issue:
Thanks
