161 - 180 of 417 Posts
95 impreza wagon
Discussion Starter #163
I lost the inner sleeves for the outrigger bushings:
W91379
I could probably just have them machined too if I can get measurements.
Can anyone help?
95 impreza wagon
Discussion Starter #165
got my hoes together
backlash looking good
passes puppy inspection
got the diff back together in spite of my massive hangover.
It can't go in the car yet cuz I lost the bushings for this mother fucker
So i started messing with the interior. Cleaned up some metal ebrake related stuff and then put the carpet in to check out what I'm dealing with
*starting* to almost look like a car again
95 impreza wagon
Discussion Starter #168
14.3 - 11.5 makes a little more than .5?
I just ordered new bushings. In the event I find the old bosses I can resell them. Quickest and easiest way to keep moving forward. :(
95 impreza wagon
Discussion Starter #173
Another stupid thing I'm doing.. I bought a power harness from a car that had foglights and a sunroof so I can try to reuse those pieces and keep OEM wiring/fuse/relay locations
I maybe need 4-6 wires from this whole fucking thing.
I'll probably just give up and make a relay harness.
OH! and I was able to just order the crush tubes from whiteline. They wouldn't let me use the promo code though. :(
95 impreza wagon
Discussion Starter #175 (Edited)
$18. Which isn't bad considering if I were to buy steel bar and by the time I mess around with it to get it correct...
anyway, diff and outrigger are in now.
got new axle seals from the dealer before I ended my progress.
axles will go on, then I can torque all the truhart links to spec, assemble the ebrake hardware, put on the wheels and drop the car for now.
I have to rebuild my brake calipers and get them coated next. then move to interior - carpet fitting, seat install, figuring out my wiring..
doors, then engine
#32
95 Coupe, 95 Sedan & 95 Wagon
That is a good price actually as you say, labor, material, etc...
Oh and to reply from before, I was thinking a 12mm bolt, thus the 11.5 comment, however, I also realized after that it could have been a 14mm bolt. Anyways, moot now!
Progress looks good man.
Happy turkey day
95 impreza wagon
Discussion Starter #177
thanks!
I'm catching slack on another forum for not doing at least a single stage on the engine bay; so I'm gonna do that.
Just as soon as I figure out how to keep my garage warm enough to spray.
95 impreza wagon
Discussion Starter #178
carpet and seats bolted in, still needs some trimming but got plenty of coverage
axles in, everything torque'd to spec
ebrake hardware put back together
back on the ground again!
only broke one clip, re stripping the engine bay so I can coat it
starting to disassemble the calipers so I can get them coated. Need to buy a fitting for my air compressor so I can get the pistons out.
