441 - 460 of 468 Posts
2001 SRP RS Coupe, 05 FXT
Damn, that looks good! Is it 86F?
EDIT: Just read back and saw you say its going to be 86F. Excellent choice.
95 impreza wagon
Discussion Starter #443
thanks guys, also turns out I didn't make it home scott free.
Exhaust slip joint broke off after smashing it too much. Need to get a replacement or just have one made.
And my axle took a shit. Wondering if the hardware flying off might have caught it cuz thats a nasty rip.
anyway.. cleaned and etching primer on the welds on the inside of the car.
here's a pic of the roof to show how smooth it turned out
95 impreza wagon
Discussion Starter #444
new axle is in.. found a leaking fuel filler hose. can't wait to drop the subframe to replace it. Fucking garage leaks so bad..
top of this hose, you can see the orange residue from the fuel leaking. it rained down the last time I filled up.
this is what my garage looks like right now so I moved inside
fiberglass for structural support
testing out the fiber optics on the non-sunroof scrap headliner
headliner wrapped.. came out OK... have some wrinkles up by the driver side visor and you can see the seam line cuz I didn't make it smooth enough but it'll do.
fit the lip on the bumper
leveled out the saggy bumper. Pass is still low cuz I hadn't bolted that side up in first pic
grill still sits too far on on driver side but its so much better than before
drain tubes and vents for sunroof
had to bend the rear of these brackets up with a large wrench cuz they were for the sedan, not wagon
rear spats on the bumper
and for more indoor rainy weather entertainment I finally made the connector harnesses for the ignition coil upgrade.
waiting for some motivation to get that fuel hose replaced, then I'm gonna have the exhaust made.
I need to find someone to color correct and coat the paint in seattle.
95 impreza wagon
Discussion Starter #446
I have, and I eventually will but when they redid the driveway it wasn't graded properly.
Also the leaking is coming from the flat torch-down roof where it meets the angled roof section.
I think I just have to take it down and start over.
95 impreza wagon
Discussion Starter #447
found some more broken shit, hoping the threads are just dirty and I can get away with a cleaning
ignoring that for now, got the subframe down a lot quicker than I expected. dunno why I dragged so much ass on it
stupd leaky hose, i bought the wrong one so that put a stop to my work...
QUESTION:
this is just a vapor line but it looks like its starting to crack in the creases... I don't think the OEM one from a WRX will work becase they don't meet the filler neck at the same place.
I feel like I should replace it while the tank is accessible - RECOMMENDATIONS for a replacement hose? Is there a material that bends better? Can I put metal in it and heat it to make bends or something?
95 impreza wagon
Discussion Starter #449
Cap it? Doesn't it need to breathe into the filler tube? I have no cannister.
1995 EZ30 Coupe
I know where you're coming from, but I have to advise against ignoring that. I've had those lines/couplers rust out on multiple old Subarus. They get really bad right where they come through the body. My SVX has no brakes right now for this reason.
That said, yours look waaaay better than mine did so you probably have plenty of time.
Edit: my plan is to move that coupler to just inside the chassis (cut/flare the lines running along the door sills under the seat) and use rubber lines to go from the coupler through the grommet to the rear brake lines. Less chance of rust in my mind, food for thought maybe.
95 impreza wagon
Discussion Starter #452
Oh I'm gonna fix it. Just its gonna wait until the fuel line is done. I'm hoping I can just clean the threads and re-bleed the brakes. fingers crossed.
95 impreza wagon
Discussion Starter #453
Yea I mean remove it all haha. It's work though.
Maybe make your own hose with a joint to change the angle since it's vapors, not worried about liquid leaks.
isn't that the roll-over valve? To delete do I just plug it? Its already been drilled out inside...
95 impreza wagon
Discussion Starter #455
still waiting on the replacement hose. I got the spring though and it works pretty well.
so I did some tidying up:
cut the sunroof drip hoses to length, put in the grommets
decided to use the airbag system for power for the sunroof. Still had an old harness so I just depinned all except power and ran it behind the dash to the sunroof plug. (There are no bags in the car or system of any kind except fuse box power FYI)
while i was testing it out I put the suede wrapped cover on the lid
I can't wait to get the whole headliner on. I bought some Dynomat and closed cell foam that I'm gonna put in before I can put the headliner on. Hopefully this weekend.
then I finally found a KPH to MPH converter so I swapped to the cleaner (simpler) speedo. Hopefully it reads decently close. the other one was 10mph too high, probably becuase of wheels?
last but not least I pu tthe rear washer bottle back in and ran new hose
Upcoming:
clips are coming for drip rails then roof rack goes back on.
then I can put the headliner all the way on, pillar covers... need to route the sunroof harness properly
fuel hoses should be here this week, then I can get back on the ground. I gotta look at that fucking brake distribution block. ughh
and get my exhaust made.
1995 EZ30 Coupe
I think Subarus tend to read high on the speedo, both my H6 wagons read close to 10 mph over at highway speeds with stock tires. My Impreza read 5 over with slightly larger than stock tires. Idunno.
95 impreza wagon
Discussion Starter #457
well I didn't die and I still have the car.
Its mostly a daily driver now.
I finished the fiber optic star ceiling
finishing up the interior
visor work
I'm not hpapy with how the blue carpet is fitting. Since I have the blue checker mats I might just install the OE black carpet I bought instead.
did the WRX coil upgrade finally
still only at 10psi but haven't hesitated yet.
heres my exhaust finished up. I love how it sounds
VIdeo cuts out cuz the photographer screams at the backfires
White Lwag
Damn, wagon looks good. Head liner is rad. How much did the sound deadening on the roof help? It's on the long list. When your sunroof is back, makes it look like an extra wing from the side.
Over all cars badass, nice work man. Any next plans for it?
95 impreza wagon
Discussion Starter #460
Hard to say how much it helped. I didn't drive it enough with the sunroof before I put it on. And also I had a different exhaust setup but its not obnoxious in the cabin which I like.
Next plans are to drive the shit out of it.
I want to make a polycarbonate sunroof skin (researching peoiple who can thermoform it for me)
Up the boost to 16 now that I have the new coils
and then fix all the little things
HVAC lights are out,
rear wiper doesn't swing all the way cuz of big wang..
power for the homelink and mirror lights in the visors..
