301 - 320 of 468 Posts
95 impreza wagon
Discussion Starter · #301 · (Edited)
block decks nice n shiny using the roloc bristle
.002" no pass!
time to install the viton valve seals
wire wheeled the stupid harness bracket. Gonna coat it
used a brushed al vinyl on the cluster bezel. Not sure if I'm 100% sold on it. Might try to do it with a dip instead.
95 impreza wagon
Discussion Starter · #306 ·
this company 23 valve tool apparently isn't made for the ej20g heads.
I had to grind the bucket down to fit inside the valve hole and its also not tall enough to gain access to the retainers after the spring is compressed.
I can get a spacer to add some height or I can just get the right fucking tool. Suggestions?
lots of wire wheelin..
probably going to shoot it with some clear coat when I'm finished. block too
95 impreza wagon
Discussion Starter · #308 ·
cleaned the block top and bottom, gonna clear coat it so it doesn't oxidize as soon as shes on the road again
finally got the spring compressor to work. had to stack up a bunch of washers
the seats seem pretty clean so I'm just gonna clean the valves and put in the new seals and call it good.
95 impreza wagon
Discussion Starter · #311 ·
finally got around to tearing into the second head
lapped the valves anyway cuz it wasn't as bad as I thought it'd be
and now I feel that much more confident they'll have a good seal
fresh and so clean
after a good brake clean and air compressor clean out
vitton seals
almost brand new
95 impreza wagon
Discussion Starter · #312 · (Edited)
Ran into a small hitch... some of the buckets didn't want to 'spring' back
I'm trying to upload a video but the ej20g v2 buckets have a spring inside the buckets and 6 of them seem to be frozen. I can't seem to get them to loosen up.
Help?
:EDIT: click for video
95 impreza wagon
Discussion Starter · #318 ·
solved it:
did some more digging. Apparently the 1.8miatas use the same style of HLA. the "stuck" ones are actually just pressurized with oil (how they'll be in actual operation) which is how they compensate for oil temps,etc. I took apart a springy one and sure enough it was dry inside. I took apart the "stuck" ones just to make sure they would move since its been sitting for so long and now everything is bouncy and ready to go back together.
for reference from Logan:
'96 OBS
Hey man. Always good to see you doing stuff the right way. It's good to know what I'll have to do eventually once doing things the easy way ends up biting me in the ass. :3 Now it's just a race to see if you finish your car before I find a way to break mine again. :D
