1 - 6 of 6 Posts
Dirty Whore
On my hybrid build up, im thinking about swapping my fmic, i was currently running a greddy gc8 fmic, but now since my set up is different im a have to re-do my IC piping, so im thinking maybe going abit bigger.
What to see what some of you guys are running and how much power you guys are putting down.
these are my specs
Ej257 block
Cp 100mm pistons
Eagle i beam rods
Stock sti crank
Sohc heads
Cobb street performer cams
Cobb springs and titanium retainers
3angle valve job
99 intake manifold
Id1000 injectors
GT3071r turbo
Invidia EL one piece header and uppipe
Linkplus EMS
98RS (Unicorn), 05 GSXR 1000
100mm.... good luck on a rebuild...
But I'm building my halves now.
EJ257- Halves
99.5mm STD Manley Pistons 9:5:1
Manley Rods
Heat Treated OEM Crank
Kings Bearings
ID850CC Injectors
Cosworth Intake
Killer B EL Header
DOM 3XTR
Haven't figured out heads yet. I'll be anywhere from 300-600whp
Dirty Whore
A few of the locals here are running 100mm making between 4-500whp with no issues, all built by Bertune, same builder as mine, but yeah i've read the reviews, but i got them for free. So they went in.
What fmic u running,
True I think i just lucked out with my block needing no machine work at all but maybe a 1/10 of a hone for standard pistons.
Mine will be custom made by a local shop seeing how I'll probably run a relocated turbo.
Dirty Whore
Discussion Starter #5
Ah, my piping will have to be custom due to the rotated set up im running, would hate to hack up my greddy fmic kit, would rather sell it and get a bigger mount while still retaining the fogs
Personally i would sell it, to fund for a custom set up. At least from that point you are starting fresh and also not having to deal with a headache.
1 - 6 of 6 Posts
