I just recently had this code pop up about a week ago. P0171...says it's running lean, but draining my fuel like crazy. Spark plugs has been changed with NGK copper plugs gapped at .44 and new wires. I'm not sure what else to change.
I have the same code popping up and also have the p0130 code. I'm assuming these too codes are related and by replacing the front O2 sensor or air fuel sensor it should fix that problem as well as the rough idling?More often than not, it is a front O2 sensor. You are going through gas so quickly because the car is running open loop all the time and running silly rich.
