1 - 2 of 2 Posts
I need to know the wire colors in the ignition harness that i need to tap into for the timer. I am not using a harness there are only 3 wires to splice just need to know which wires to splice into. I need a constant 12v, acc12v and something directions is calling ignition switch. 1993 imp L.
Discussion Starter #2
I never found out via the web or wiring diagrams so I just cut into the harness and used a tester. Heres what I found:
RED - KEY POSITION ON
RED/YELLOW - KEY POSITION ACC
BLACK/YELLOW - CONSTANT 12V
BLUE/RED - TO STARTER
This is from my 1993 L but I doubt the wire colors are different at least for GC bodies. Now I have a boost gauge and a turbo timer yay. Hopefully someone will be able to use this because its not on rs25, scoobynet, nasioc or scoobymods.
Thanks
Garrett
1 - 2 of 2 Posts
