I recently installed a Legacy turbo setup on my car, and it has been creaking when I go over a bump. I am pretty sure that it is because I am using a Legacy Turbo crossmember and the RS front sway bar. This is probably causing the sound, but it could also be the bushings worn out in the sway bar. Anyone ever have a nasty creaking sound from under the engine after you go over a bump?
Graham
Graham
